Displays the DHCP/BOOTP Relay statistics and the configuration for the VRs.
| ipv4 |
Specifies unconfiguring the DHCPv4 BOOTP Relay service (default). |
| ipv6 |
Specifies unconfiguring the DHCPv6 BOOTP Relay service. |
| vlan |
Unconfigures BOOTP relay for a specified VLAN. |
| vlan_name |
Specifies the VLAN name. |
| include-secondary |
Removes the include-secondary configuration for the specified VLAN. |
None.
The fields displayed in the DHCP Information Option 82 section depend on the configuration defined by the configure bootprelay dhcp-agent information policy [drop | keep | replace] command. If the policy configured is keep, the Requests unmodified counter appears. If the policy configured is replace, the Requests replaced counter appears. And if the drop policy is configured, the Requests dropped counter appears.
The Opt82 added to Requests counter indicates the number of DHCP requests to which the BOOTP Relay agent (the switch) has added its own option 82 information.
The following example displays the DHCP/BOOTP relay statistics for existing VRs:
Switch.1 # show bootprelay Bootprelay : Enabled on virtual router "VR-Default" DHCP Relay Agent Information Option : Enabled on virtual router "VR-Default" DHCP Relay Agent Information Check : Enabled on virtual router "VR-Default" DHCP Relay Agent Information Policy : Replace DHCP Relay Agent Information Remote-ID : "default" Bootprelay servers for virtual router "VR-Default": Destination: 10.127.8.1 DHCP/BOOTP relay statistics for virtual router "VR-Default" Received from client = 2 Received from server = 2 Requests relayed = 2 Responses relayed = 2 DHCP Discover = 1 DHCP Offer = 1 DHCP Request = 1 DHCP Ack = 1 DHCP Decline = 0 DHCP NAck = 0 DHCP Release = 0 DHCP Inform = 0 DHCP Information Option 82 packets statistics for virtual router "VR-Default" Received from client = 0 Received from server = 2 Requests replaced = 0 Responses dropped = 0 Opt82 added to Requests = 2 Note: Default Remote-ID : System MAC Address
# show bootprelay
Bootprelay : Disabled on virtual router "VR-Default", but enabled on some VLANs.
Include Secondary : Disabled
DHCP Relay Agent Information Option : Disabled on virtual router "VR-Default"
Received from client = 0 Received from server = 0
Requests relayed = 0 Responses relayed = 0
DHCP Discover = 0 DHCP Offer = 0
DHCP Request = 0 DHCP Ack = 0
DHCP Release = 0
DHCP Inform = 0
Information about DHCP/BOOTP relay being disabled for the VR, but enabled on some VLANs was added in ExtremeXOS 22.5.
